Question Regarding CPU i think - Help!!
Mar 4, 2019
13
So i bought this computer with the information that it should be able to run csgo smooth. i have a 144 hz monitor as well, but im only having around 100-120 fps with alot of fps drops and laggy tendencies, this takes the smoothness away and therefore the actual joy of playing. I really want everything in csgo to be butter smooth, and im willing to do whatever it takes.. so community my question is, do i need to replace some hardware in my pc, or are my speccs good enough, just me making mistakes or blocking something?
Seeking help!
- heres my system info.
I have the DxDiag ready if you need any information.
Thanks!
Many regards, Chris.
Machine name: DESKTOP-16BVV6U
Machine Id: {D47D0575-0AF9-43BF-94A2-B0F1705AF995}
Operating System: Windows 10 Home 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
Language: Danish (Regional Setting: Danish)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 05/12/16 11:52:13 Ver: 05.0000B (type: BIOS)
Processor: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz (4 CPUs), ~2.8GHz
Memory: 8192MB RAM
Available OS Memory: 8046MB RAM
Page File: 6911MB used, 9134MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.17134.0001 64bit Unicode
This is a family friendly site.
Mind your language.
Lutfij
You might want to relist your specs like so:
CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz 2.80GHz (Skylake 14nm Technology)
Motherboard: ASUSTeK COMPUTER INC. B150M-A (LGA1151)
Ram: 8,00 GB
SSD/HDD: 223GB SanDisk SDSSDA240G (SATA (SSD))
GPU: NVIDIA GeForce GTX 1060 6GB
PSU: Model no: RS-500-ACAB-B1
Chassis: unknown (big cabinet)
OS: Windows 10 Home 64-bit
For the sake of relevance, include the make and model of your PSU and it's age. We can move forward from there.
My computer is around 2-3 years old, but it has the same problems as the day i bought it, and it havent shown reduced performance since, neither better performance.
Thanks for your time!! I can provide furthermore information if needed.
