G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Hi
I have an old GW 333 mhz with w98SE that I use and am having a problem. I
recently installed Symantecs System Works on my Laptop (WXP)and had zero
problems with the installation, then I tried installing it on the old
desktop with zero success. I went to Symantec read the faqs also
downloaded their remover software and ran it and even went to MS and
dowloaded the MS installer remover software. Still no luck. I searched
the computer looking for any remainders and even used the uninstallers
recommended by Symantec for 2002 NAV and NIS. No luck. Keeps saying it
cannot install either NIS or NAV (particularly rescue and the virus
checker). Prior version was 2002 and am now using 2004.
The only thing I can see is Symantec Script blocker and am wondering if
that might be a problem. This has me perplexed to say the least. Any
ideas or comments would be appreciated.
Hi
