[SOLVED] Reliable PC suddenly failing to POST. MB standby LED on but no response. Dead MB or PSU or something else?
Apr 28, 2021
Hi all,
Apologies if someone finds a duplicate for this thread - any similar ones I've found, the solution hasn't worked for me, so I figure I'll ask my own question.
I stepped away from my PC to take lunch yesterday, and it had switched off by the time I returned. No response at all when I press the power button. Bad switch maybe? Also no response when I jump the power switch pins myself.
I've stripped it right down to core components (it needed a good dusting anyway) to help diagnose the problem:
  • ASUS Z97-PRO GAMER motherboard
  • Intel i5 4690K CPU
  • 1x4GB HyperX 1866 DDR3 RAM in A2 slot (originally 4x4GB)
  • EVGA Supernova NEX650G modular ATX PSU - 5 yrs old but no issues til now
  • Samsung 850 EVO SSD 250GB (boot drive)
Also connected:
  • Corsair H55 AIO cooler (fan and pump connected to CPU_FAN and CPU_OPT on mobo)
  • CPU power, MB power, and SATA data & power cables
  • USB and HDMI out to keyboard and monitor
That's absolutely everything connected in the system right now, no luck with posting let alone booting.
When I power on the PSU, the motherboard's SB_PWR (standby power) LED comes on. No other response.
When I jump the power_sw pins, there's a small ramp on the PSU fan, but no other response.
When I disconnect the MB cable from the MB and bridge the GND and PS_ON pins, there's again a small ramp on the PSU fan and a slight charging of the capacitors (any other pwr/gnd voltage diff gives a steadily declining voltage after the PS_ON is grounded). PS_ON and +5VSB* are steadily at 5.2V whereas no other MB cable pins have a voltage.
I've not had a component outright die on me yet since I built this in December 2015 so I've not had to diagnose the error before.
Does anyone have any advice about what might be failing and/or what tests might help verify this?
Thanks a bunch,
Lexi
Follow up: I've removed the RAM and SSD. None of the Q LEDs on the board light up (particularly looking at the DRAM_LED). This has to be the PSU or motherboard right?
* correction
avg9956
Respectable
Apr 7, 2019
404
94
1,890
108
I would not eliminate the possibility of the motherboard, see if you can spot any burnt or inflated capacitors.
However at this stage, its easier if you can get a hands on another PSU to test it out. Trip to the computer repair store would do.
Judging by your description that the PSU at least still runs.
2015 and its now 2021, a good 6 years. There may be some visible wear on the caps on the motherboard. Usually motherboards are durable, but that also depends on what capacitors they use and their VRMs.
Although I really don't suspect that for like the vast majority of the cases and it is highly unlikely, but if you happen to have a screw or any metallic object lying around inside the case and happen to short something then that would possibly explain it.
avg9956
Respectable
Apr 7, 2019
404
94
1,890
108
