jacob
96
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
ok here is the problem I can have people conect to me but when thay want me
to look at there computer it says some like unable to resalve host name or
something like that and wont let me conncet to them.. but if I ask for help
from the thay can get right in what do I do
G
Guest
Guest
Yes...I'm looking for the solution to the exact problem! Please help!!!
G
Guest
Guest
Greetings Jacob,
This error simply means that you're unable to connect to your contact. Are they using a
router or anything similar? If so, they may be using a router without Universal Plug and
Play (UPnP) support/enabled in which case Remote Assistance will not work through it.
____________________________________________
Jonathan Kay
Microsoft MVP - Windows Messenger/MSN Messenger
Associate Expert
http://www.microsoft.com/windowsxp/expertzone/
Messenger Resources - http://messenger.jonathankay.com
All posts unless otherwise specified are (c) 2005 Jonathan Kay.
You *must* contact me for redistribution rights.
"Jacob" <Jacob@discussions.microsoft.com> wrote in message
news:78772923-9637-44A1-9A21-E89EA37504A9@microsoft.com...
G
Guest
Guest
Hi Jonathan,
Thanks! In our case, both computers are behind wireless routers. I just
checked the "expert's" router and UPnP was not enabled. I won't be able to
test it until later...Does UPnP need to be enabled on the novice's router as
well? Does Windows XP have to be configured for UPnP also?
Does the UPnP configuration explain the situation that one expert can
connect to the novice but another expert can't?
Thanks again for your help!
"Jonathan Kay [MVP]" wrote:
> Greetings Jacob,
> Jonathan Kay
> Associate Expert
G
Guest
Guest
This might not be your case, since you said you had wireless routers
in the mix. However, 99% of the time that I get "hostname" problem
when trying to connect to friend's machine is when they have Zone
Alarm or another firewall running (it's nearly always Zone Alarm
though). So you might want to check if the person you are trying to do
remote assistance with has Zone Alarm running, if they do, get them to
turn it off while you're trying to connect to them for remote
assistance and it should connect.
On Sat, 17 Sep 2005 00:42:02 -0700, "Anyone please help!"
<Anyonepleasehelp@discussions.microsoft.com> wrote:
>Hi Jonathan,
>> Greetings Jacob,
>> Jonathan Kay
>> Associate Expert
G
Guest
Guest
Anyone please help! -
news:4235A4C6-EE03-42CD-B9D0-33DAAE8AEA3A@microsoft.com :
> novice's router as well? Does Windows XP have to be configured for
> UPnP also?
Maybe UPnP helps, I don't know, but it's not mandatory.
I use remote assistance (as an expert or as a novice) behind a non-UPnP
router, and everything works fine.
