G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hi all,
I'm having a strange problem using Remote Desktop Connection on an XP
Pro machine. The host computer is on Verizon DSL with a linksys
router and ZoneAlarm running.
I can connect to the machine and use it without problems from my
office, and also when dialed into an isp from a hotel.
However, when I try to connect via my Moms computer or my Aunts
computer (both running XP pro on Comcast from two different houses), I
get the login prompt, am able to login and I can see the desktop load.
However, at this point it locks up - ie, any keypresses or mouse
clicks result in just a 'beep' and the click is never registered on
the host machine.
I figure it must be something with the comcast network, but I can't
imaging what the problem may be that it allows a connection, a login,
but no interaction once logged in?!?
Any help?
ThX!
Hi all,
the host machine.
Any help?
ThX!
