Question Remote Desktop Connection not displaying on ALL 3 monitors ?
Jan 4, 2023
I have 3 monitors connected via a Dell E-Port Advanced Replicator. 2x connected via Display Port and One connected via VGA.
The 3 displays work perfectly when navigating in windows and using applications. As soon as I attempt to use a remote desktop connection for my work I have it only displaying on a single monitor, despite the multimon settings being set under the display tab. I've even tried running using the mstsc /multimon and overriding the txt file of the RDP profile to set the multimon:i:1 tag.
Any suggestions on a fix?
USAFRet
162,524
13,892
176,090
24,478
So far as I am aware RDC doesn't support multi monitor. I believe if you go into the remote machine and hit the windows/P key it will display a message concerning said.
Correct. RDC does NOT do multiple screens.
I just confirmed this on mine.
RDC from a Win 10 VM to the main box (Win 11, 3 screens)
The RDC only show the one, whichever is identified as the Main screen.
