G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have windows 2000 server with Service Pack 3 and my workstation all
running windows xp pro with no service pack. My work's server is a domain
controller and which contains the active directory. All my workstations are
on a domainI enabled remote desktop and I even portfwd 3389 on my linksys
wired router. I even made all the workstation that i worked on have a
static LAN DHCP address. The internet works and i even see our map drives
work. I even check remote desktop exception in the default windows firewall
that came without service packs 1 and 2. I even check to allow remote
desktop to happen in System Properties remote tab.
We have a static WAN address which is connected the linksys router. My
linksys router has the static WAN IP address option, and filled in the
correct IP address, default gateway, DNS server, and the correct subnet
mask.
Anyhow my problem is my latop at home which connected to my wireless router
does not connect via remote desktop to my work's pc.
The funny thing is i can use remote desktop client and type my static WAN IP
address at my collegue's workstation and it works. Once I leave my LAN
connection at work, it does not work.
When i try to ping <ip address or DNS>my work WAN IP Address from my home
DSL it is timed out. But when I try to ping my work's STATIC WAN IPS from
my workstation or any of my collegue's workstation at work it gets a ping.
mask.
