Jim
2,444
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hi Al,
I get the following error message:
"The client could not connect to the remote computer.
Remote connections might not be enabled or the computer might be too
busy
to accept new connections. It is also possible that network problems
are
preventing your connection. Please try connecting again later. If
the problems continues to occur, contact your administrator."
I hope this helps,
Jim
Message 2 in thread
Subject: Re: Remote Desktop Issue?
So what error message, if any, do you get when you try to connect?
Are you positive your calling the correct IP of the RDP host?
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the
mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no
rights...
"Jim" <jim1.20.spamfree@antichef.com> wrote in message
news:d97b5ae1.0412241135.163e14be@posting.google.com...
> Hello,
> I'm having a problem connecting to a host PC through a dialup
> connection. The firewall settings are set right on all PCs.
> The client PC has had a problem connecting to Kaazaa Lite also.
> The client is running Norton internet security. Both PCs are
> running WinXP Pro SP2.
> Any advice would be appreaciated.
> Thanks,
> Jim
Newsgroups: microsoft.public.windowsxp.work_remotely
Date: 2004-12-24 11:42:41 PST
rights...
> Hello,
> Thanks,
> Jim
Date: 2004-12-24 11:35:45 PST
Hello,
Thanks,
Jim
G
Guest
Guest
The PC your trying to connect to using RDP is it behind a firewall/NAT/router or directly connected
to the public internet? If its on a private LAN can you access over the LAN from another PC on the
same LAN? If its behind a firewall/NAT/router is TCP Port 3389 open to the private LAN IP of the PC?
Are you calling the correct public IP of the firewall/NAT/router or PC?
This page has a few troubleshooting tips that may be of interest....including a telnet test from a
remote PC to check on port forwarding...
http://theillustratednetwork.mvps.org/RemoteDesktop/RemoteDesktopSetupandTroubleshooting.html
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
This posting is provided "AS IS" with no warranties, and confers no rights...
news:d97b5ae1.0412250750.6a085bc5@posting.google.com...
> Hi Al,
> busy
> are
> I hope this helps,
> Jim
> Message 2 in thread
> From: Sooner Al (SoonerAl@somewhere.net.invalid)
> rights...
>> Hello,
>> Thanks,
>> Jim
> rights...
>> Hello,
>> Thanks,
>> Jim
> Hello,
> Thanks,
> Jim
