Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Glad you solved the problem....
Jeffrey Randow (Windows Networking MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows Network Technology Community -
http://www.microsoft.com/windowsserver2003/community/centers/networking/default.mspx
Windows Home Networking Community -
http://www.microsoft.com/windowsxp/expertzone/communities/wireless.mspx
On Fri, 15 Oct 2004 08:33:05 -0700, "smanders"
<smanders@discussions.microsoft.com> wrote:
>I did not reboot, however RDP was not the only application that was not
>working properly. It was just the most critical one I needed. I went ahead
>and followed all the directions on the web site and everything worked
>beautifully. All my apps are still installed and I did the "admin" version
>of installing the service packs and I installed SP1 then SP2. All the
>expected applications were in place.
>Thanks so much for your help,
>smanders
>"Jeffrey Randow (MVP)" wrote:
>> Did you reboot after the regsvr32 command?
>> On Thu, 14 Oct 2004 11:19:03 -0700, "smanders"
>> >I tried the "regsvr32 remotepg.dll" and it popped up a success window, but
>> >the tab was still not present. I am following the directions of the link
>> >provided. I wanted to mention though that the wpa.bak and the
>> >undo_guimode.txt were not present on my system. The only mentioned file that
>> >was present was the wpa.dbl. I did backed that up, and proceded with the
>> >install. I will post my results.
>> >Thanks again for your help,
>> >smanders
>> >"Sooner Al" wrote:
>> >> Try reregistering it using the command line that follows...
>> >> Otherwise do a repair install of Windows XP.
http://michaelstevenstech.com/XPrepairinstall.htm
>> >> NOTE THE WARNINGS ON THE REFERENCED PAGE!!!!
>> >> Al Jarvi (MS-MVP Windows Networking)
>> >> Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
>> >> The MS-MVP Program -
http://mvp.support.microsoft.com
>> >> This posting is provided "AS IS" with no warranties, and confers no rights...
>> >> "smanders" <smanders@discussions.microsoft.com> wrote in message
>> >> news:4E4E061B-D48B-4BDD-AC27-EC69ADB0A347@microsoft.com...
>> >> > The CD was a Pro Version and if I go to the General tab under the System
>> >> > Properties says its:
>> >> > Microsoft Windows XP
>> >> > Professional
>> >> > Version 2002
>> >> > Service Pack 2
>> >> > But no Remote Tab.
>> >> > Thanks,
>> >> > smanders
>> >> > "Sooner Al" wrote:
>> >> >> In message <70B0B533-5401-4335-B286-C27237DA4AE4@microsoft.com>,
>> >> >> "=?Utf-8?B?c21hbmRlcnM=?=" <smanders@discussions.microsoft.com> wrote:
>> >> >> > I installed XP cleanly from a CD. Then I did the windows update and it
>> >> >> > prompted me to go directly to SP2 without installing SP1. I though sure,
>> >> >> it
>> >> >> > would pick-up all that I needed. Now when I go to the System Control Panel,
>> >> >> > the Remote tab is not present. How do I enable the Remote tab? Do I need
>> >> >> to
>> >> >> > install additional software? I tried going to the Add/Remove Windows
>> >> >> > Components and there was no option for Remote Desktop.
>> >> >> > Please help,
>> >> >> > smanders
>> >> >> Is this an XP Pro machine? If its an XP Home machine then the Remote Desktop
>> >> >> tab will not be available.
>> >> >> Posted with Ink Spot (for PocketPC) from DejaVu Software, Inc.
>> >> >> Usenet wherever you are - http://www.dejavusoftware.com/
