FOUND IT!!
Looking down at case lying on its side, there is a metal tab on the right side of the PSU which you simply push down to release....
Slides right out 😀
Thanks,
FOUND IT!!
Slides right out 😀
Thanks,
FOUND IT!!
Slides right out 😀
Thanks,
Thank you. I was finally able to get it out using a mini pry bar. I didn't see the tab so I had to do it the hard way.
