remove cpu fan from heat sink
ryanbruns
Commendable
Jun 23, 2016
Can the cpu fan be taken off the heat sink on my fhs-a8025s-s999 cpu cooler? please help... I ordered a new fan with led's and i want to replace the fan for better air flow and better looks. Thanks!:bounce:
Hard to tell, from the pics I found online it looks like the fan is molded into the heatsink mount which is what holds it to the motherboard. If this is the case its not removeable. You are probably better off getting an aftermarket cooler that has a removeable fan.
