Removing blur from NINJA BLADE
bunana
34
Can anyone give me some suggestions on how to remove the blur from this game? It is so bad that its enough to make you think you have gone blind.I know in some games you can go into the files and adjust it but I don't know which files to change/remove. I'm running a fx 6300 with r9 270 so I know my fps are 60+ and not causing the blur.
