Removing/disabling rooted/system bloatware?
shafe88
854
Anyway to remove/disable factory installed bloatware? Just got a new phone and I'm having trouble removing/disabling the bloatware that came preinstalled from the factory. I wasn't able to remove, any of the bloatware, but was able to disable some of the bloatware but not all of it and it's draining my battery. All the bloatware app's are missing the uninstall button, and some of the bloatware apps have the disable button grayed out.
This is one of the apps I'm trying to disable/remove.
http://
I've tried rooting, but none of the apps/methods seems to work. My phone is a ZTE majesty pro LTE from TracFone.
Have you googled how to root that phone at all?
The vast majority of times you cant just root a phone with an app, it requires a much more complicated procedure. Some of those apps are bogus, some are designed for one specific phone but not marketed that way, some are advertisement click bait, and most that you download outside of google play store are viruses/malware.
