Question Removing front panel on Sharkoon DG7000
Mitch_15
84
How do I remove the front panel of my Sharkoon DG7000 case? Its getting really dusty i need to clean it but i cant remove it
Check, if there are screws or latches, holding front panel in place.
If there are screws/latches, then unscrew screws, unhook latches.
If you have optical drive installed, then that has to be removed first.
Then just rip front panel off.
Post some photos, if still need assistance.
(upload to imgur.com and post links)
Mitch_15
84
Sharkoon have two variants of the DG7000. Which one do you have? There should be a small cut out for your fingers to go into and tug the front panel off the reach the dust filter behind front fascia.
as long as i know its just called sharkoon dg7000 there is a small opening below the penal
