Removing hard drive cage?
codi passaro
31
Is there a way you guys would suggest removing a hard drive cage, that is not removable? I will be upgrading my computer soon, and I don't want to buy a new case, I already have a decent one, I just does not have a removable hard drive bay, so I won't be able to fit my new GPU in it.
I have been told just taking a flat head screw driver at a 45 degree angle, will take take it out, but I want more opinions. I will be upgrading this case obvious in the future, but as of now, I can't upgrade it.
My case does not have a sticker indicating anything to do with a brand, maybe it's under the motherboard, or maybe just a off brand case, so I can't say what kind of case it is.
I have looked, and im pretty sure its not removable. But I don't mind having to forcibly remove it, so my question is what is the easiest way of forcibly removing it.
