M Milborne Commendable Dec 7, 2016 1 0 1,510 Dec 7, 2016 #1 I never really thought about having to clean it before, but it's disgusting. However, I don't see any way to make it out. Anyone happen to know how?
Solution clutchc Dec 7, 2016 There should be a hand grip notch under the bottom edge of the front panel. Pull on that. It may be tight and hard to pull loose.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Dec 7, 2016 Solution #2 There should be a hand grip notch under the bottom edge of the front panel. Pull on that. It may be tight and hard to pull loose. Upvote 1 Downvote Solution
