G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hello, from a DV newbie. I am learning enough to be dangerous but I
am a newbie nevertheless.
I have my home theater hooked up to my PC via a Canopus ADVC-100 (plus
a digital coaxial for sound output to the home theater) and I use
Vegas 5.0 for video capture/editing along with Sound Forge 7.0 for
non-trivial sound editing and DVD Architect 2.0 for burning onto DVDs
(CD Architect 5.0 for CDs).
To be honest I haven't burned a single DVD yet - only one SVCD (which
looked darn good when I played it).
Right now I capture from firewire to DV. I do elementary editing such
as trimming, transitions, etc, then when I am done I render to NTSC
DVD mpeg, with the idea that I can watch it on my computer, later burn
it on DVD if I want, or even play it with Vegas via firewire and the
ADVC-100 to my TV.
Now I discovered that DVD Architect (DVD-A) will recompress/transcode
the source before burning onto a DVD unless the source was rendered
with the DVD-A Vegas mpeg video-only template. I am not sure I
understand this - if I am going to separate video and audio in Vegas,
how am I going to sync them back in DVD-A? Can it do this like I do
with Vegas? and of course now I lost the convenience of playing video
and audio on the PC with just a double click 🙂
I am interested in learning to do this the 'right way' so I can store
finished clips in some kind of compressed format that can be viewed on
the pc and be reimported in Vegas or DVD-A for future projects.
Is it common practice to store clips that might be used in the future
in DV (avi)? Also, is it common to just use DV in DVD-A - for a
newbie like me it's simple and I imagine since there is (almost) no
compression there should be no quality problem as there is from
rendering mpeg back to mpeg (yikes!)
Is there a commonly accepted 'bible' book that explains the workflow
and processes without assuming expert knowledge of the video/audio
field.
regards,
Kiriakos
ADVC-100 to my TV.
field.
regards,
Kiriakos
