• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Reolace HDD with SSD, with Optane module in system
stevenlyall
6
I've replaced system HDDs with SSDs before, with no problem, but am having real difficulty with my new Dell, which has an Optane module.
I disabled Optane and booted from a USB downloaded from Dell with Factory OS. I was sure my SSD was the only hard-drive installed.
The OS build reached 75% and failed, with little more info than 'something went wrong'. This happened twice.
I put everything back as it was, and re-enabled the Optane. To my surprise, some files I'd left on the SSD were untouched. This made me think that the OS was perhaps directed to the Optane module, and failed because it's so small.
Does anyone have similar experience?
Any advice would be appreciated.
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
Disable Optane, turn off the system and remove the optane drive itself and try again with the ssd.
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
No problem, it could also be a block from Intel themselves seeing as Optane was meant to speed up old slow hard drives not SSD's, also your not going to notice an improvement with an Optaned ssd over a normal ssd, its been tested.
stevenlyall
6
Agreed - I wouldn't have ordered Optane if it had been an option, it just came with the bundle. I may even leave the module out. I was delighted with SSD in my old computer, and am sure I will be delighted with it in my new one - when I get it working. Thanks....
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
You can always sell the Optane module or use it in a different Optane ready board.
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
Good, the system may have been reading the Optane module as an M.2 drive or something and tried to install it to there. If you want you can put the Optane Module back in, but you wont notice a difference since SSD's are really fast.
stevenlyall
6
In the end, I did reinstall and enable Optane, just for completeness. I agree that there is no noticeable difference relative to the SSD, which is running superbly. Many thanks for the auto-defragment tip - now disabled for the SSD.
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
LinusTechTips tested running optane with an SSD and there was no improvement at all, but it does massively speed up a hard drive.
stevenlyall
6
It certainly accelerated the HDD, as I tested that with and without Optane. Now I hope that the Optane isn't slowing the SSD down!! System certainly running well.
jacobweaver800
Respectable
Dec 15, 2017
1,539
209
Yes it does accelerate HDD's very well, but it could be slowing your SSD depending on if the SSD is hooked up through Sata 6gb/s or not.
Similar threads
