hello i have gtx 980ti with bad 1vram adn will work if i remove wihout replace only remove vram will work?
Won't work with removed module.hello i have gtx 980ti with bad 1vram adn will work if i remove wihout replace only remove vram will work?
hello a repair two gpu with bad vram replace and pass but i no have vram for gtx 980ti thanks for answers
i have three gtx 980ti all has bad vram i repair two gpu but on one not have vram for replace can use elpida vram if i have sk hynix vram on pcbCan you rephrase this more clearly? I am unable to parse this.
You would probably have to switch to a VBIOS where the replacement memory was originally used, and I don't think that mixing memory vendors / types is going to work or is a good idea. If you're replacing one chip with a given type and it's not the same as the rest, all chips need to be replaced. At least I'm fairly sure this is the case.i have three gtx 980ti all has bad vram i repair two gpu but on one not have vram for replace can use elpida vram if i have sk hynix vram on pcb
i testing on gtx 660ti and rx 550 2gb i remove on vram from rx 550 and solder on gtx 660 ti and work but i no have idea if work on gtx 980ti and rx 470 if i solder from rx 470 to gtx 980tiYou would probably have to switch to a VBIOS where the replacement memory was originally used, and I don't think that mixing memory vendors / types is going to work or is a good idea. If you're replacing one chip with a given type and it's not the same as the rest, all chips need to be replaced. At least I'm fairly sure this is the case.
