Random Reboots and BSOD with various .sys errors. Windows event viewer show numerous HD errors, some CPU core errors with various cores and memory.dmp errors. I have two of these exact Gigabyte B450M DS3H boards with F30 bios. One board is Ryzen 2200G, Gskill DDR4 3000 RAM and the secon board other (one I am having problems with is a Ryzen 5 1400 and Neo Forza 3200 RAM. The second board mentioned has the 5 1400 that works fine in the first board mentioned but keeps resulting in these errors in the second board. I have tried three HDDs, 2 PSUs, 2 GPUs, swapped RAM and swapped CPUs. The 2200 G works fine in the second board that I suspect to be bad while all other variables are exctly the same, BUT when I put the Ryzen 5 1400 into this second board (exactly the same model and BIOS as the other ) the PC crashes 20 times per day-basically unusable. I have requested and RMA on this board, but I am not 100% certain.
Anyone got any ideas before I mail this board off for RMA? Thanks for help/suggestions.
