Repair weapons. Help
G
Guest
Guest
Archived from groups: alt.games.morrowind (More info?)
Hi everyone,
I've be playing MW on xbox for some time now, and I just bought
the pc version so I could use the construction set. I'm at level 3.
My problem is that I can't seem to repair any weapons/armor.
I have tongs, Journ... hammers, and can bring up the window
that show what needs repairing. I can scroll thru them, but I
can't use the hammer. Do I need to be at a higher level? I never
had a problem with xbox doing repairs. I'm assuming the left mouse
button is the use button, no go. I tried space bar, and all the other
keys, but no go.
any ideas?
The little paragraph on p29 does not show anything special.
Thanks,
El Boa
"El Boa" <Someone@nowhere.net> wrote in message
news:tp91t0h3tn2m7e5ccbckmnc9furp2t8frg@4ax.com...
> Hi everyone,
> keys, but no go.
> any ideas?
> Thanks,
> El Boa
Select repair item and drag it to your portrait.
On Tue, 28 Dec 2004 05:17:43 GMT, "ALMA ENGELS"
>> Hi everyone,
>> keys, but no go.
>> any ideas?
>> Thanks,
>> El Boa
I don't think that will work. What I do is select the hammer or tongs
that I want to use and drop that on my character. That brings up the
list of things which can be repaired. Then I left-click on the item I
want to repair After the report of success or failure, I keep
clicking until I run out of hammers and tongs, or everything is
repaired.
Nyctolops
>> Hi everyone,
>> keys, but no go.
>> any ideas?
>> Thanks,
>> El Boa
When I select a damage item and equip it. It does not repair.
If I select the repair hammers and equip them, I get the repair
screen, but the left mouse click does not work. Now I am
thinking I may have a problem with the mouse. I am using
MS optical wheel mouse.
Any help or suggestions appreciated.
Thanks,
El Boa
On Mon, 27 Dec 2004 23:20:24 -0700, Nyctolops
>>> Hi everyone,
>>> keys, but no go.
>>> any ideas?
>>> Thanks,
>>> El Boa
>repaired.
This is what I have been doing, but when I left click, nothing
happens. I'm not having any other mouse problems, so i
do not think that is what it is. I do get the list of things and
can scroll down through them, but no repair.
El Boa
news😛872t015ouldk1ufgmskr7tgscg9e7rg58@4ax.com
>>> Hi everyone,
>>> other keys, but no go.
>>> any ideas?
>>> Thanks,
>>> El Boa
> Thanks,
> El Boa
I'm using a MS Wheelmouse Optical, default XP driver for it, and its on
a USB port, not PS2. No problems with it in game at all. My own
Armorer skills were kinda low. I went thru a LOT of hammer
kits.....well, still do :) But I can't see why this isn't working for
you. Your Button 0 is assigned to Attack, right?
McG.
On Tue, 28 Dec 2004 12:19:54 GMT, "McGrandpa"
>>>> Hi everyone,
>>>> any ideas?
>>>> Thanks,
>>>> El Boa
>> Thanks,
>> El Boa
>McG.
Yes
Is there a restriction on the character/race one is using?
I set this one up as a wood elf being a theif. Maybe he
is too weak to pick up hammer. <grin>
El Boa
On Tue, 28 Dec 2004 12:24:44 -0600, El Boa <Someone@nowhere.net>
That's not it, as I have an almost identical character and he can
repair things. It takes him forever, as he is not very good at it,
but he can repair things.
This might sound silly, but it has happened to me. When you
left-click, is your pointer on the item or on the name of the item? I
can't get repair to work unless the pointer is actually on the item
itself. If I point to the name of the item and click, nothing happens
at all.
Nyctolops
On Tue, 28 Dec 2004 12:56:00 -0700, Nyctolops
>at all.
That was it!!!
Thanks! I guess I was so use to be able to click anywhere in the xbox
version that I did not try just the icon. Sweet! I was not looking
forward to having to return to the "smith" all the time.
Hats off to you.
El Boa
