Replace CMOS Battery Toshiba Satellite
level101
307
I need to replace the CMOS battery in a Toshiba Satellite 2415-S205 & not sure the best way to go about it.
Every time the battery goes dead I have to reset the time & date.
Thanks for your help
roadrunner197069
Splendid
Sep 3, 2007
4,416
Toshiba is on of the few companies that actually post good directions online how to dis assemble their Laptops. There is a ton of screws. You have to take the HDD and DVD rom out if the battery is on top of the Mobo. It can be real tricky putting it back together. Buy yourself a $10.00 model car and if you put it together go ahead and do the toshiba. If you dont have the patience or skill on the model take the Toshiba to a shop.
G
Guest
Guest
Legal preface: This is how I, personally was able to get it done, easily.
I just did one of these (2400-S201) to see if I could give them a second life, and to see if it was all that bad
...Its not.
Keep in mind, this laptop is older, but very much worth resurrecting.
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
6. Return your model car with reciept. If a reciept cannot be found, use it for store credit.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
This seems a little complex, but it really isn't I did one after a few barley pops in about 15 minutes.
Please feel free to give a shout out if anyone finds this helpful.
debrusky
...Its not.
Thank you so very much for giving such precise instructions. You are a prince; gave me ammo when taking the laptop to the experts. Merci beaucoup and mille grazie.
dasamman
O.K., now where is the cmos battery on a Toshiba Satellite A205-S5823? And is it possible to bypass a BIOS password or is there a viable backdoor? I am working on one of these for a friend. I power it up and I get a password request.
ccalxr
sure you are.... anyway, take the plate off the RAM bay. Remove the two sticks of RAM. In one of the corners of the bay on the motherboard you will notice two solder points with XXX right by them. Take a flat head screwdriver (one that is made of metal) and rest it on the two points so that it is touching them at the same time. While doing this turn the computer on. This should short the BIOS and and reset the password.
P.S. dont try to remove the CMOS battery as it will do absolutely nothing
G
Guest
Guest
What's the significance of removing the RAM when the two solder points (in which you describe) look to be fully accessible? I'm just curious before I go putting sharp pointy things inside the laptop ...
Pointertovoid
327
9
Removing the Ram is just an old, well-known method... BUT less known is that many computers, especially older ones, especially laptops, keep the information in Cmos Ram for >20min (observed at my Scenic Mobile). So a short-circuit or a foreseen short is a faster, more reliable method.
But to keeps settings, including the date-time, just replace the battery not too slowly.
I also read that salts deposed by finger sweat can cut the life expectancy of a Cmos battery from years to a few months. Perfectly credible to me. So wear gloves, and wipe the battery before inserting it. It doesn't cost anything at least.
Older laptops do have backdoor passwords, like Awkward for an Award Bios. Lists exist on the Web.
By clearing the Cmos Ram, you clear the password and the date-time, and all other settings as well, so don't forget to put them back. At the very least, load the default settings. It can make the difference between a working computer and a seemingly broken one.
ShinBerry
Hi,
I think I have an issue with my cmos battery on my toshiba sattelite p200-1FY as the computer is not switching on anymore (well it start switching on and then stops).
I wanted to know if there was a specific cmos battery that I needed to get, like a specific type ?
Thanks a lot!!
Delphi51
I am replacing the CMOS battery on a Toshiba Satellite A20, and appreciate the clues here. The disassembly instructions here
http://www.irisvista.com/tech/laptops/ToshibaA20/Satellite_A20_replace_hinges_2.htm
were of great help. I did the first 19 steps. LOTS of screws and quite time consuming. I used masking tape to hold the screws in their original locations so I didn't lose or mix them up.
If you click on the picture for step 19 to enlarge it, you will see the green battery left of the trackpad, between two ribbon cables. It is a 1620 3V Lithium calculator battery with wires welded on and a connector that plugs into the motherboard. I see you can buy them for $5 plus shipping. I figured I'd better get the job done NOW before I forgot how to put the laptop back together. I pulled the connections off the battery and tried to solder them onto a new CR2032 battery. No go! Neither the battery or the metal strips on the wires would solder. I ended up taking the battery holder out of an old watch and using it plus some electrical tape to make the connection.
G
Guest
Guest
...Its not.
hi can you help me i changed battery other day and after i put back together it has green light but will not power! i was very carfull and it was actuly very easy to do but now i have a hole new problem! thank you
