I had to move my Dell 7050 motherboard to a new case as my need out grew the old case. I added a 1050 GPU and had to add a new power supply. But the mother board has a 6-pin ATX plug in and the new power supply doesn't match the plugin. The 6-pin connector has 2 white wires, 2 black wire, 1 thin green wire and 1 thin brown or gray wire. The power supply is a L240ES. I would like to wire the 6-pin into the 20-pin connector that came with the new power supply. I need a voltage pin out for the 6-pin any help would be awesome.
