Replace for AMD Athlon II 240 Dual Core cooling fan
EasyLearner
4
HP did not have any information regarding the part I need. My fan is making too much noise. I am looking for a replacement fan for AMD Athlon II 240 Dual- Core and all is listed on the HP parts side is for Heatsink - AMD Class D (Fox). Any suggestion and where to buy? Thanks.
According to your link above, this is your motherboard: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02458055
It uses a conventional AMD retention bracket for mounting a CPU cooler. You're in luck.
If you want a stock cooler like you had, you'll have to find a new or used one on someplace like ebay. That CPU is long ago obsolete.
Here's a new one for AMD CPUs up to 95W (yours is only 65W). http://www.ebay.com/itm/AMD-Socket-FM1-AM3-AM3-AM2-AM2-1207-940-939-754-4-Pin-CPU-Cooler-Up-to-95W-/321979578219?hash=item4af77a776b:g:h44AAOSw~bFWJ8Wh
It is the Pavilion P6547c Serial number: MXX0240PCQ
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02257729&DocLang=en&docLocale=en_US&jumpid=reg_r1002_usen_c-001_title_r0001
HP Pavilion p6547c Desktop PC Product Specifications
Hardware
Software
Product number
WW589AA
Hardware
Base processor
Athlonll X2 240 (R) 2.8 GHz (65W)
4000 MHz HyperTransport 3.0
Socket AM3
Chipset
AMD 760G
Motherboard
Manufacturer: Foxconn
Motherboard Name: H-Alpinia-RS780L-uATX
HP/Compaq motherboard name: Alpinia-GL8
Power supply
250W
