Replace Front 200mm Fan in Corsair Graphite?
Derico
341
Hi,
I want to replace the noisy front 200mm Fan. I already took care of the top 200 mm and the rear 140mm fan. The problem - as all of you corsair graphite case owners know - that its hard to find a fitting 200mm fan for the front mesh.
The Bitfenix Spectre Pro for example can only fit in the front, if you move the hard drive cage. Sadly, that is not an option for me. The regular Bitfenix Spectre does fit, however, it can only be mounted one way (exhale).
I'm desperately trying to find a 200mm inhale fan, though.
Thank you for your links. But the whole point of the thread is that im looking for a 200mm case fan for the front side of my Corsair Graphite 600T case that a) fits in and b) is inhale. The case does come with (amonst others) a 200mm on the front but it's simply too noisy if you're trying to build a silent-pc.
I've ordered and sent back 2 200mm Fans already because either they didnt fit or they required me to modify my case in a way that was not an option for me. So im hoping to receive advice from another corsair graphite owner who maybe found a fitting one?
