Replace front fan of Sharkoon Vaya II (120mm)
Thanks for the quick answer. Got one of these to replace the intake fan. Will report on how it goes.
So, I put the front fan in yesterday and was able to reuse the screws from the standard Sharkoon fan on the BitFenix one. It runs with no problems since the first install. Temps and sound are a bit better than before. Thanks for the help!
Can you tell me how you removed the front panel?
