Replace mb in a Acer Aspire M1100 now front panel does work.
Gondorff
6
I needed to replace the mb on a Acer Aspire M1100. I removed the old mb and installed the new and reconnected all the cables. Then reloaded the operating system, everything when find and the system was up and running.
But then I need to get some pictures of a SD card, when I put the card into the reader nothing happened, I tried another card but the same thing. Then I got a SmartMedia card and tried it still nothing.
I then checked the Computer Hardware Manager to see if there were and problems but I found nothing wrong.
Next I reopened the case to system and checked if the plug was in the socket properly, an it was. Howerever the only place that I could plug the plug into was labeled 1394. I looked around for another socket but did not see anything.
Since this is a OEM mb it is impossible to get information on it, not even a picture of where things are plugged in.
There is a similare mb from Foxconn - A690GM2MA-RS2H but it is different enough to make it useless for help.
Anyone have one of these mb and could you tell me if I have the front panel plugged into the proper place.
Thanks
Use a usb pin connector instead of the 1394; unplug one of your front usb connectors if needed. I connect the 4 pin white connector on the 4 pin side of the usb pins for my card reader. Here's your m1100 board: http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fsearch.yahoo.com%2Fsearch%3Fei%3DUTF-8%26p%3Dacer%2Bm1100%2Bmotherboard%26type%3Datt_lego_portal_home%26hsimp%3Dyhs-att_001%26hspart%3Datt&w=501&h=480&imgurl=www.ascendtech.us%2FmmASC%2FImages%2Fmbs8809001_1.jpg&size=179KB&name=mbs8809001_1.jpg&rcurl=http%3A%2F%2Fwww.ascendtech.us%2Facer-aspire-m1100-rs690m03-motherboard_i_mb64ars690m038e.aspx&rurl=http%3A%2F%2Fwww.ascendtech.us%2Facer-aspire-m1100-rs690m03-motherboard_i_mb64ars690m038e.aspx&p=acer+m1100+motherboard&type=&no=1&tt=115&oid=63D55E568354477B6C4CFD8E2A30BB8E1C8FF4C5&tit=MB.S8809.001+MBS8809001+%7C+Acer+Aspire+M1100+RS690M03+Motherboard&sigr=12mamv37t&sigi=11f3disaj&sigb=13nd4tghn&fr=yhs-att-att_001. The usb plugs should be the yellow ones; loks like you have three. If you are using a different board now, please list the model number using cpuz.
