I have a Netgear Aircard 790s modem. The charging port is a micro b USB 3.0 but the charging cable is only micro b USB 2.0. As a result the cable connection is very loose, falls out, doesn't connect properly etc etc. This means the modem does not charge without a lot of fiddling to get the cable at just the right angle and depth.
I have tried the following:
Is there anything else I can try?
Can I replace the port with just a micro b USB 2.0 port? Or is that a stupid idea?
I'm hoping there is a fix for this as the modem is new.
Thanks
- different micro b USB cables (still doesn't connect well)
- cleaning the port
- a micro b USB 3.0 cable (this fits snuggly but doesn't even show as successful USB connection, let alone charge)
Thanks
