Replace monitor for higher resolution (1920x1080 > 3200x1800) ASUS ux303ln
cookiebowz
21
Hello, i own a ASUS ux303ln with a resolution of 1920x1080 and with a dedicated gpu (optimus). This laptop exist in 3(?) versions. Do you think it's possible to replace the monitor with a QHD+ monitor at 3200X1800 as they are exacly the same except the monitor and gpu? (The QHD+ one has only intel graphics.)
You would need to verify that it doesn't require any more pins or a different terminal by taking the screen off of your laptop and finding the pinout for the data/power connector. If they are the same connector with the same pinout then it could work fairly easily if you can get your hands on the 3200x1800 panel.
