G Guest Guest Aug 16, 2010 #1 Hello, i replaced cap on viewsonic monitor now it wont turn on at all any ideas what i may have done?
G Guest Guest Aug 16, 2010 #2 I've repaired two Viewsonics so far without a prob. Suggest you check any other 16 to 20 volts capacitors on the power supply board. Obviously, observe polarity and correct values (though a slightly high voltage type is okay). Upvote 0 Downvote
