Ok, so, on Old Ironsides (see sig), I'm using a donated PSU - an OEM Dell 460W unit. However, the fan in the PSU was rattling, so I decided to get a replacement. It's a 92mm fan, with a tiny 2-wire connector that plugs into the PSU's board.
At first, an excess of caution made me think I should go for an exact replacement. An ADDA Corp AD-0912US-A70GL, which is a 2-wire, 12V, 0.30A fan.
Unfortunately, wherever I could find them, they were coming from China, and I decided that maybe I'd go for something that could be at least sourced in-country (US).
I went with a Zalman ZM-F2, figuring the size was the same, it was 12V with less power draw, and advertised to be quiet. I had to cut the wires and splice, as it, like many other fans, had a standard 3-wire connector.
It works. But, I have to admit, it doesn't seem like it pulls air with much force at all. I like that it's near silent, but I'm not all that confident in its ability to move air, particularly given that the case aslo has a small mesh filter for the PSU intake. I'm not entirely sure its actually running at its full speed, and, in hindsight, probably should've connected it to a MB header with its original connector so I'd have a point of reference.
I think I should probably get something a little better, but would like it to be:
- relatively inexpensive
- sourced from a supplier in the US
- reasonably quiet
