A awgarre Sep 11, 2018 2 0 20 Sep 11, 2018 #1 acer es1-511,i have replaced battery with acer original. but says 0% not charging. the original battery works so do i need to do a setup of somekind
Solution A A awgarre Sep 11, 2018 yes it is an OEM battery. exactly the same as the one i removed. AP13B3K is the battery (a non removable)
webworkings Titan Apr 6, 2016 11,201 0 86,610 Sep 11, 2018 #2 Did you buy the new battery through Acer or through another place? Wondering if it is actually a OEM battery. Upvote 0 Downvote
kerberos_20 Champion Dec 24, 2011 9,967 1,604 55,740 Sep 11, 2018 #3 check if that new battery has clean contacs, maybe it has still some plastic protection on it? Upvote 0 Downvote
A awgarre Sep 11, 2018 2 0 20 Sep 11, 2018 Solution #4 yes it is an OEM battery. exactly the same as the one i removed. AP13B3K is the battery (a non removable) Upvote 0 Downvote Solution
webworkings Titan Apr 6, 2016 11,201 0 86,610 Sep 11, 2018 #5 Does it have the exact same specs as the original battery? I would compare the two to be sure. Upvote 0 Downvote
