Question Replacement Blower/Cooler
stuffwhy
13
I have an Asus GTX 1060 with the blower cooler design. While not damaged or defective, the fan is starting to become noisy, I think due to some slight torquing as the card bends under its own weight, which is sort of its own issue. I'm not sure if this will be covered under warranty, but I've noticed that there really aren't many replacement graphics cards cooling solutions out there except for a handful of giant and/or expensive ones. Is this just how it is? Can anyone recommend something I might have missed?
There are aftermarket coolers like from artic.
Also there should be replacement fans for it, on ebay or similar sitea.
You can manually dissassemble the cooler and put little grease onto the shaft.
The fan on back where the sticker is the clip that holds it, if there is one.
Or the ball bearings got stuck and shaft ate itself and its making noise
