Question Replacement case for Gateway
Gateway FX 6860 uses mATX board. The case is ATX.
So it obviously fits and leaves a lot of unused space, since it's significantly bigger than necessary.
But the case is all bling and no performance with seriously hindered air intake.
DSzymborski
Well, it still probably has better airflow than the original!
More seriously, OP, I'd also recommend something a bit more practical. Cool things like tempered glass and RGB stuff should be features you go for when a case already gets the important stuff, like proper intakes, correctly.
geofelt
What is your objective in buying a new case?
Your gateway pc included a dvd drive.
The case you linked did not have space for a dvd drive.
Cases with dvd drive space are a bit more limited, but there are some good ones out there.
