Question Replacement CPU AIO for my PC ?
tlavanway3
237
Hello, i have a Corsair One i165 Compact Gaming PC with an RTX 2080 TI and a i9-9900k.
I was wondering what I could replace the Factory AIO with for the CPU, thanks.
I did some searching and it looks like they'd used custom control setups for some of the models around then so you should probably contact Corsair directly. The radiators in that model are already slim versions so I'm not sure how easy it would be to get an AIO that will fit period.
Reactions: Phaaze88
