Current case i have antec twelve hundred (1200). Main problem is get in to those hdd's. I have 3 ssd and 2 hdd and nearly impossible to change hdd when all cables are between graphic card and hdd's. Maybe the best part of this case is L-M-H switch for casefans and front panel manual casefan speed switch.
So far i have narroved selection to Corsair Graphite 730T and 760T. Correct if i'm wrong but the only difference between those two are window side panel on 760T? How much more noise 760T makes through if there is all 5 140mm fans at low or high speed compared to 730T?
Are there any other options for case i should look for at the price of 760T?
One other thing do you guys recomend using Scythe Master Pro 6 channel fan speed panel?
