Replacement for ASRock Z68 Extreme4 Gen3
MelTorefas
21
I moved a few months ago, and recently had my computer (purchased January 2012) shipped up to me. Unfortunately, the video card and motherboard were damaged in shipping. Fortunately, the insurance claim paid out, so I was able to replace the video card. Now I am working on finding a replacement for the motherboard.
As mentioned in the title, the damaged board is an ASRock Z68 Extreme4 Gen3. It still works for the most part, but one of the PCI express slots is destroyed, and there may be other problems. I have been getting some weird issues that I certainly didn't have in the pass, and memory and CPU diagnostics have been clean, so I would definitely like to replace the board if possible. That said, I can't find any available Z68s for purchase except a few very expensive options.
So, I was hoping someone might be able to recommend an equivalent board that will be within or close to the amount the insurance paid out ($85). I can pull in a bit more money for it if really needed, but I am hoping there will be something in that range. The CPU is an Intel core i5 2500k, and the case is a CoolerMaster Haf 912. If any more information is needed, please let me know, and thanks for your time.
okay here is what I found so far
1-ASUS P8Z77-V PRO Socket 1155 Mainboard w/ VGA DVI HDMI and DisplayPort, DDR3 2600, PCI Express 3.0 x16, 3-Way CrossFireX and SLI, SATA 6Gbps, USB 3.0 - Refurbished
link : http://pcdirect.com//asp8proso11m2.html
and
http://www.newegg.com/Product/Product.aspx?Item=9SIA6BM35P3504&cm_re=z77-_-9SIA6BM35P3504-_-Product
Asus link : https://www.asus.com/us/Motherboards/P8Z77V_PRO/
2- New - Intel DZ68BC Desktop Motherboard - Intel Z68 Express Chipset - Socket H2 LGA-1155
http://pcwarehouseoutlet.com/index.php?route=product/product&product_id=14192
There are no ASRock Z68 Extreme4 Gen3 motherboards on ebay that I can see (I looked there before posting here). I see other motherboards in the 'related items' section, but I don't which would fit my situation best (hence this question), and most are far more expensive than I can presently afford. So, unless I am doing something wrong in my search, it sadly will not be that simple.
you can look for the Z77 chipset , they also accept i5 2500K but comes with usb3 ports instead of usb2 on the z68
and
Finally back around and able to reply. Thank you, this was exactly what I was hoping for. That motherboard looks perfect, and now I've got it ordered. Appreciate it!
