Hi all. I'm looking to replace a GTS 250 with something new in an old HP p6310y to breathe some life into it. Would like to stick with nvidia, but also stay under/around $100. Most intensive thing this computer does is play the latest Sims games.
Someone at a store suggested a GT 730 GDDR5, but when comparing spec sheets on that to the GTS 250, the 730 appears to have less Memory Interface Width than the 250 (64 vs 256), Memory Bandwidth (40GB/s vs 70.4), and for the width they appear to be different (dual-slot vs dual-width). I honestly can't say I understand the difference between those 3 things, so hoping someone can tell me if i should be concerned about those 3 differences or not.
Or if someone has a different card they would suggest, I'm all ears.
I really appreciate the help, I can't afford a new computer but I think this upgrade would make it much more enjoyable for all to use.
