Replacement for GV-R928XOC-3GD (rev. 2.0) alternatives
shotii
Commendable
Feb 17, 2016
Hi Guys,
Previously my GV-R928XOC-3GD (rev. 2.0) - r9 280x rev 2.0 got broken so I've RMA it to Gigabyte. After several months of waiting they've decided to replace it but they don't have the same model so they offered me GV-R929WF3-4GD 1.0 - r9 290 1.0 should I accept it? I know r9 290 is faster(not completely sure) but I've been reading a lot of negative reviews(blackscreen issues)http://www.tomshardware.com/answers/id-2471771/gigabyte-290-windforce-crash-black-screen.html to r9 290 particularly the Gigabyte brand.
What do you guys think? Thank you
The blackscreens are caused by radeon settings not by the card and yes accept the 290 in a heartbeat.Just roll back your driver to pre crimson and ull be fine till they fix it a...
Hi,
Is r9 290 really that broken?
I never owned a 290 before so I can't comment on the black screen. I do however know that it usually runs quite hot compared to other cards.
The blackscreens are caused by radeon settings not by the card and yes accept the 290 in a heartbeat.Just roll back your driver to pre crimson and ull be fine till they fix it a new one is coming at the end of february
Thank you. Is r9 290 revision 1.0 is faster than r9 280x OC revision 2.0?
