Hi,
I am having issues with my wireless card connecting at 5Ghz. But at 2.4 G it's all good. There are times the card does not even see my 5GHz SSID, I may have to play around with the wireless properties or just wait it out. When it does see the 5GHz network, it could take minutes for it to connect and then it stays connected. If I reboot the machine then I have to go thru this song and dance all over a gain. At my location the card can see a handful (like 20 other) wireless networks both 2.4 and 5G.
I am not 100% sure if it is my router / extender at fault or the wireless network card but I can leaning towards the network card since all my other wireless devices are working fine at 5GHz. In the router extender set up, I have is the Actiontec G1100 router (with all wireless turned OFF) that is MOCA connected to the Actiontec WCB6200 wireless extender which has the wireless radios turned ON.
The laptop I have is a Latitude e6540 with the Intel Centrino-N 6300AGN card. I believe the form of this card is the half-mini PCIe. I am looking for a replacement card of the same form but more recent. The 6300AGN is discontinued and the driver version (15.16.0.2) and dated back to 01/06/2015. I cannot find more recent drivers. I did some searches and found the 7260N to be in the same form but this is also discontinued.
I reinstalled win 10 x64 (2004) on the machine and I have the same issues.
Are there any other wireless cards of the same form that I can use in this e6540 Latitude?
Thanks!
Thanks!
