Replacement for mobility radeon 4100
mailman59
36
Can someone help me find a replacement graphics card thats better the radeon 4100. I own a laptop that a couple years old and I was wondering if I can replace it for a new one.
My laptop specs are: Satellite L500d, 4gb ram, 32 bit os (It's 64 bit compatible), dual AMD Turion Mobile M520 and directX 10.
If you can help please leave a comment.
trapper
679
You'll need to upgrade to a new laptop unfortunately. Laptops - unlike desktops - aren't built for upgradability down the road but rather to fit anyway they can into the case. As such most parts are build into the mobo and no separate entities.
mailman59
36
thanks
