Question Replacement for old gpu help
goga12
270
I had a r9270 that died is a Rx550/570 a good replacement for it or a 1030/1050 ti and Wil it work with my cpu a fx8350 and ddr3 ram I have a 550w psu
an RX570 would be the best of what you listed.
a 1050ti is roughly the same as the 270 you had and both the 550 and 1030 would be a step down from the 270.
don't know where you are looking to buy or what your budget is, but from what you listed i'd go with the 570
Latest posts
