APPROXIMATE PURCHASE DATE: Within 2 Weeks
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Office Applications
PREFERRED WEBSITE(S) FOR PARTS: Newegg, Tiger Direct
PARTS PREFERENCES: None
OVERCLOCKING: No
SLI OR CROSSFIRE: No
BUDGET: Approx. $200
ADDITIONAL COMMENTS: As stated in the usage section, this is only for office applications. The PC it is going in is a Dell Dimension B110. After a power outage the other day, the PC fails to power up at all (no fans, beeps, etc...) and the MB has been identified as the culprit. I just need a recommendation for a good MB/CPU combo to get that will fit the Micro-ATX case. I was planning on using the same RAM, but as GhislainG suggested, it's really not worth it. I'll also need a heatsink/fan if the MB doesn't come with one.
OVERCLOCKING: No
