Replacement of amd fx 6300 stock fan
Thanoj
45
my stock amd fan had been broken , what I find in the internet is above 3000inr
I live in india currently I cannot afford those I want a cooler less than 1000 inr ,just looking similar to a stock fan running my pc
This fan should run way quieter than your AMD stock HSF and should run slightly cooler. It's by Deepcool, a manufacturer that I personally trust, and for 599 INR (just under 7 quid here), that should do the trick just fine.
https://www.flipkart.com/deepcool-gamma-archer-cooler/p/itmda3j3qs3g59kg?
Hope this helped :)
Hope this helped :)
really thank you you saved my time
