B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 29, 2017 #1 i have a old k7n2 motherboard could you tell me a good replacement please i would like to use the same tower case if possible
Solution K K Kasper Jorgensen Oct 30, 2017 barry1949 : Yes but will it fit in our old case this was built in 1996 If it's an ATX case then yes. Anyway, you can get a new ATX case for as little as around $20 so that is not whats gonna blow your budget.
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Oct 29, 2017 #2 Any reason you wanna waste money into such an old platform? Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 29, 2017 #3 just wont to rebuild it with new components but motherboard must fit the case wife not wanting to change only needed for office work Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Oct 29, 2017 #4 Problem is that it will be very hard to find that, and if you do it will probably be way overpriced. You will need to find a motherboard with socket A/socket 462 and a AMD 760 chipset i believe. Best bet is to look at ebay if you can find one. Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 29, 2017 #5 better to buy new case then and build from there Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Oct 29, 2017 #6 Yes it is better to start a new system, but probably no need for a new case unless you like. You can assemble the new system into your existing case. Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 30, 2017 #7 Kasper Jorgensen : Yes it is better to start a new system, but probably no need for a new case unless you like. You can assemble the new system into your existing case. Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 30, 2017 #8 Could you recommend a motherboard for this case please Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 30, 2017 #9 How about the Msi b350 would that fit my case Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Oct 30, 2017 #10 Choose a CPU first before deciding which mobo to buy. You will need CPU, motherboard, DDR4 ram at least and possible a new PSU. Upvote 0 Downvote
The Paladin Titan Ambassador Oct 5, 2016 9,663 62 75,340 Oct 30, 2017 #11 1. what country are you in ? 2. how about : https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.XMS-6570.TRS5&_nkw=MS-6570&_sacat=0 Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 30, 2017 #12 Kasper Jorgensen : Choose a CPU first before deciding which mobo to buy. You will need CPU, motherboard, DDR4 ram at least and possible a new PSU. Upvote 0 Downvote
B barry1949 Distinguished Oct 13, 2011 9 0 18,510 Oct 30, 2017 #13 Yes but will it fit in our old case this was built in 1996 Upvote 0 Downvote
K Kasper Jorgensen Estimable Jun 10, 2017 3,080 1 3,960 Oct 30, 2017 Solution #14 barry1949 : Yes but will it fit in our old case this was built in 1996 If it's an ATX case then yes. Anyway, you can get a new ATX case for as little as around $20 so that is not whats gonna blow your budget. Upvote 0 Downvote Solution
