Replacement power cable
G
Guest
Guest
Hello,where can i get part GB A4y273 47604 435 htgr
(monitor made march 2004)
if the power cord is a plain type without any sort of special transformer then you can use a generic cord. the socket that fits into your monitor is commonly used on many other perepherals so it should be cheap.
if you need a special cord with a transformer then you could try amazon, ebay, or your monitor manyfacturer.
