Replacement screws for an HP ZR24w monitor
expatCanuck
64
Hi folks -
I've got an HP ZR24w monitor. The screws to attach the monitor to the stand were lost in a recent move.
Per the manual, the monitor includes:
Eight 10 mm mounting screws (for attachment to VESA compliant monitor mounts)
Eight 15.5 mm mounting screws (for attachment to HP Thin Client products)
Four 20 mm mounting screws (for attachment to back of select HP flat panel monitor stands
I suspect that I need the 20mm screws, tho' I'd like to get the 10mm screws as well, just in case.
Can anyone provide a more complete spec for the screws (i.e. - one that includes the width and/or thread description), or suggest where I might obtain the screws?
Thanks kindly,
- Richard
hardware store or something like that will have machine screws which is what you need. take the monitor in carefully wrapped or in it's box if still have it so you get the right size diameter screws as they might be 8-32.
