Asking if it's a Okay to take the 1600RPM fan from the CRYORIG H7 place it in the front or side of case, and replace it and rear fan with the Cryorig QF120 performance 2200 RPM? Case is VIVO CASE 03B. The stock fans are 1000 RPM. I don't care about LED. Just Quiet and Efficient.
I want to then put the Cryorig QF120 Balance 120mm in front and side then Cryorig QF120 performance 120mm PWM Fan 600-2200 RPM over the heatsink and rear. I have a PC desk with Tower cabinet.
PC specs:
VIVO CASE-V03B
ASUS M5A99FX PRO R2.0
CRYORIG H7
AMD FX-4350
KINGSTON HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3 CL10 DIMM X 2
PC specs:
VIVO CASE-V03B
CRYORIG H7
AMD FX-4350
