[SOLVED] Replacing air cooler fans
I'm certain that you can.
Same manufacturer, same fan construction, same dimensions. I don't see any reason you'll run into fitment issues.
Besides, the retaining clips included with the cooler is universal. It will fit practically any 120mm fan that has standard mounting holes.
Thank you for your answer!
