Hello everyone. This is the first time I'm installing custom fans for my PC, so please bear that in mind as I have no prior knowledge on how to do this.
I'm buying a Corsair LL120 RGB 120mm 3-pack and 2*140mm LL140 RGB fans for the front of my case. Two of the 120mm fans will be replacing the fans of my top-mounted H100x AIO, and the last 120mm will be replacing my exhaust fan that came with my PC case.
The LL120 RGB 3-pack comes with a Corsair Lightning Node Pro and RGB Fan LED Hub.
My question is; do I connect all the fans except for the ones that attach to my radiator to the RGB hub, and the AIO fans the motherboard? or do I attach every single fan to the RGB hub?
Also, it seems my case (Svive S650, an in-house brand from the retailer) has a fan hub installed, do I swap this out with the new fan hub from Corsair as all my fans will now be directly from Corsair? Thank you in advance for the help!
Items:
LL120 RGB 3-pack:https://www.komplett.no/product/964137/datautstyr/pc-komponenter/vifterkjoelingvannkjoeling/vifter/corsair-ll120-rgb-120mm-3-pk
LL140 (buying two of these):
https://www.komplett.no/product/964140/datautstyr/pc-komponenter/vifterkjoelingvannkjoeling/vifter/corsair-ll140-rgb-140mm-vifte
Items:
